By mospeada11
#8563
Would you know whether an after market hood damper kit has been produced for the 1989-98 Suzuki Swift?
#8564
Don’t think so, can’t be that hard to make though, I’m sure there would be a market for at least a few that piece is always destroyed.
#8565
macuserman wrote: Fri Jul 03, 2020 9:13 pm
Hood damper?
#8567
suzukitom wrote: Fri Jul 03, 2020 11:15 pm
damper = bumper
Those 2 rubber screw in thingies that keep the edge of the hood from fluttering when latched closed
Makes complete sense now that I’ve been schooled, I was thinking something hydraulic like a steering damper. The Japanese call it a cushion.
#8568
mospeada11 wrote: Fri Jul 03, 2020 8:17 pm
#12 in the image. $2.54 us each. How many do you want? https://www.megazip.net/zapchasti-dlya- ... el-3815006
By suzukitom
#8571
just in case the original poster was referring to a hood/bonnet strut lift system .. you can make one out of two worn out rear hatch door strut lifts.. and some brackets . when the rear hatch lifts lose gas pressure its usually just the perfect strength to raise and support the lighter metal metal hood/bonnet.
#8572
Man and here I was thinking he meant the padding on the underside of the hood. :laugh: :laugh: I think we need the poster to clarify.
By suzukitom
#8573
macuserman wrote: Sat Jul 04, 2020 7:46 am
The pad under the hood/bonnet is called a ‘silencer’, which most definitely means something else in America.
I’m now sure the original poster was referring to the hood lift support struts , as there is a commercial website named exactly that which sells kits.
unfortunately no listings for Swifts here:
http://bonnet-damper.com/shop/en/22-suzuki?p=4
bought more parts....a running, somewhat driving […]
A word to the wise. SRD are rip off artist. Avoid[…]
I tighten my alternator today, cleaned down the ca[…]
