- Tue Jul 14, 2020 1:57 am
#8639
Somewhere along the way I downloaded a magazine article describing how Whiteline sets up the Swift Mk2-3 suspension. ‘Real Handling for your Suzi Swift’
They gave settings:
Front: Toe zero, camber -1.75 and caster +4 deg
Rear: toe +2mm out both sides, camber -1.5 deg
Then mentioned needing Whiteline kit 2380 to adjust the rear camber. Internet found no info on what that kit contained. Anyone know?
Could a Cam bolt be used at the bottom of the rear knuckle where it bolts to the control arm? (Same type of bolt used on front struts)
Or offset bushings (for camber not caster?)
They gave settings:
