Documents, manuals, wiring diagrams, faqs....
By Swifterthanu
#122
I have one in my possession. Covering the Mk2 / Mk3 I don't know the cross referenced GM parts numbers as this is a Suzuki Genuine Product Parts Catalog.
#327
Does your part manual give a Suzuki part number for a left rear sway bar mounting pad that would be found in a 1991 Turbo Firefly?
By Teeth
Posts Custom Donations Avatar
#329
62715-60B00
If it has a part #, you can find it here:
https://translate.google.com/translate? ... 13103/3_78
I'm not sure why that link takes you only to the SOHC engine electrical page, but back up and browse around (Yay Google Translate!) and you can get part numbers for other engines and models.
#337
Thank you. Now where can I buy one?
By Teeth
#339
Are you looking for the steel reinforcement that is welded to the unibody that carries the threads for the bolts?
Nowhere for sure. If you are just looking for the bracket that holds the bar, I bet someone has one as I presume they are identical to GTs of the same year.
If you can't cut one off a salvage yard car, and maybe even if you can, it is always possible to install the bar as you would an aftermarket bar on a car that never had them, by drilling through the floor of the hatch and getting hardware long enough to run bolts through to the other side. You should reinforce when installing by running the bolts through a flat steel or aluminum bar extended all the way between the mounts on the hatch floor (hardware store purchase) to act as a washer and keep the trunk from splitting.
By Swifterthanu
#344
https://www.megazip.net/zapchasti-dlya- ... er-3813675 This site is great to find parts and order from. I have SGP Rubber coming through Japan from Hungary.
#369
Teeth wrote: Thu Jan 11, 2018 9:00 am Are you looking for the steel reinforcement that is welded to the unibody that carries the threads for the bolts?
Yes thank you I am looking for that. I have one from a 95 for the left side but it is way different than the right side. I have three choices. Hope to find an original piece (won't hold my breath), reshape and cut/alter the piece I have, or create a new piece from scratch. The right side is in. I will only use the drill and reinforce route as a last resort.
#390
First order of this post is to graciously thank Teeth for the part number!
Swifterthanu wrote: Thu Jan 11, 2018 10:51 am https://www.megazip.net/zapchasti-dlya- ... er-3813675 This site is great to find parts and order from. I have SGP Rubber coming through Japan from Hungary.
Well Holy Fawq! I just paid $28.74 US for a factory stamping including shipping and a promise of delivery for no later than February fifth. GM charged me $180 for theirs. Damn I'm liking the helpful people in this forum! :P
By Swifterthanu
#430
fireflyse wrote: Sat Jan 13, 2018 10:42 pm First order of this post is to graciously thank Teeth for the part number!
Family helping family
By Edgardoswift
#449
Does it cover convertibles? A guy wants to buy some.top parts from eBay but doesn't know how to search for them.because he doesn't know the parts name.
