- Sun Feb 25, 2018 8:10 pm
#626
In case you didn't see it on TS, I'm working on something right now and may soon have available pistons in stock and .5mm oversize for use with both DOHC and all years of G10/T3.
They will use the large 19mm pin, grooved for stock retainers and provide very close to stock (Turbo3) compression on G10 and approximately 8.75-1 on DOHC. I have some on the way and will have more details when they get here and I'm able to both take measurements and mod them for either application.
Post here if you're interested or have questions. They should require significantly less work than the D16 pistons and will be priced accordingly.
Contact 3tech: [email protected]
