- Wed Jul 31, 2019 4:43 pm
#5912
I’m considering these for my next engine. I reached out to the seller for more details and this is what he said:
Hi Ivan,
Stock springs are 50Lbs installed, these are 70Lbs so up 20Lbs or if you like, a 40% increase.
Fitted at the stock height the max valve lift is 12.9mm. If you need more tension then a .060 shim brings the seated pressure up to 85Lbs (71% increase over stock) but drops the available max valve lift back to 12mm.
16 units to a set.
Let me know if there’s anything else you need.
Regards,
Allen
Performance Valve Springs
Not sure what the benefit of these boils down to with regards to HP, but it’s intriguing anyhow.
Hi Ivan,
16 units to a set.
Regards,
Allen
Admin of the Suzuki Swift Repository, as well as a GTi fanatic! Currently own a Red 89 GTi and a Black 93 GT .
