Place for chatting and discussing anything unrelated to swifts.
#10356
busy week, with 7 am starts….but getting stuff done. issues with one customers mower, been back 3 different times, finally did a leak- down test to confirm my suspicion of the engine being worn out- and it was, blow-by thru the rings into the crank-case, out the dipstick and exhaust…poor exhaust valve as well…
another one was a friend of the owner- tune up special, but wanted the engine rpm higher, so he could cut deeper grass….but on the honda mowers, they are set to a min and max rpm…you move the governor spring for more rpm, but then the carb needs to be re-jetted , or else it pulls fuel thru the choke passages, making the engine run rich, blowing black smoke, but not necessarily rev any higher….
it was just fine when it was done 2 months ago….it came back, he said he even took it to the honda shop, and they changed one of the springs, but it still didnt run right, so he brought it back to me, even after the honda shop mucked with it…
so i deep cleaned the carb (nothing wrong there ) checked the valves and it ran good…he picked it up, but then it came back again…this time same issue…so i checked the carb AGAIN, and ste everything back to oem specs…proper spring, in the proper spot, factory rpm….ran great when it left the shop, i even cut some grass with it…
DAMMIT it came back AGAIN….would not idle down….it has a ‘off- min-max ’ throttle control… the cable is good, and adjusted properly…i never touched that…
so i backed out the throttle plate stopper screw, even further from the factory setting, to get the rpm down to a low idle , when the lever was put at turtle, then revved up to operating speed when at rabbit on the lever …
i told him that there must be internal issues with the governor assembly, and that i could look at it but it would be 1 hour shop time +parts to take the engine apart and put it back together ( $200 +)
plus, the honda mowers are a '‘gentleman’' lawn mower—they dont like being tweaked outside of their normal operation zones….they are a lower revving quieter running honda engine…
and what makes it worse is that its the bosses friend….when you own a business, you need to know the difference between customers, friends, and then the friends as customers that take advantage of your services….
oh, and the truck the boss bought for his kid ? sounds like the transmission is shot…revs up to 4000rpm and finally gets moving, after a block or so it drops in rpm and shifts…
he mentioned he will take it to a shop to fix the transmission after he buys his kid a different truck…
i mentioned ''thats at least a $2300 bill" and he was surprised….this guy has no clue on anything…. :-o
#10364
makes for a good day when its a bunch of easy trimmers to do… 4 of them had plugged spark arrestors, the 5th had way too much oil in the gas…
dump out the customer’s fuel…i have no clue what the mix is, or how old…even if its fresh and full, i dump it out…
then pull the muffler and check cyl/ piston for scoring…any scoring and its junk. they wont build compression properly, or once hot they wont re-start…from there onto the tune up, if cyl/ piston is good…..
burn out the arrestors with a propane torch, run the trimmer at full throttle for 10 minutes to burn the oil out the muffler, install arrestor, tune carb, wash trimmer head.
today i tackle a Tecumseh oil leak…really oily mower came in for a tune up, oil leaking from the case halves….lots of oil… after it was cleaned up and running, the oil was running / bubbling out between the halves…gasket blown out. fun fun.
and at least 2 mowers a week , with the blades installed wrong (up side-down)….and they still manage to cut grass like that… :laugh:
a warranty pressure washer from - invermere, bc….'‘no power, doesnt run properly, shuts off’'
they are shipped with no fuel…but this one had no oil, but half full of gas ???
fill the oil, it fired up on the second pull…hooked up water, and it worked with no issues….none whatsoever…even tried it 3 different times and no issues ….made really good psi, unloader valve works properly, no leaking / cracked pump…
so the parts guy called canadian tire , in invermere, and let her know that the pressure washer is going back, that we can find no issues with it, it must be operator error.
the people at ct should be a little more involved when doing warranty work…they assemble this stuff, they should have a clue if its warranty or just operator errors….
but it keeps me busy….
#10365
splitting the case and replacing the gasket on that one engine was easy peasy….once the lower half (oil pan) was off you could see where the gasket was damaged right from factory…
so, cleaned off the old gasket, a thin film of permatex on both halves, install new gasket, crank seal and assemble…
run engine, no leaks…
i wish people would pick up their stuff….lots done, running out of room, and more stuff keeps coming in… :x
#10366
blueturbofly wrote: Thu Jun 10, 2021 7:03 am
Notice to Customers: A storage fee of $10 per day is added to all orders after completion of repairs.
Problem solved and anything earned can go to the food bank.
#10367
there is a sign on the wall, as well as printed on the invoices, that we reserve the right to sell the customers item after 30 days, to recoup parts/ labor….i dont know if thats ever been enforced…
i can understand , that when its raining out, people dont think of picking up their lawn equipment…
lots of salvage mowers…that takes up room…at least 9 mowers that get moved daily , out and back in the bay door…some are for repair/ resale, some are outright parts only….but i dont have the time right now to repair mowers for resale…MAYBE i will sneak one in per week, that way i dont have to keep juggling them around the shop…
i am only 7 days behind on invoices, not that bad…as long as an item doesnt need parts that we dont stock, its fairly quick .
some people are surprised / annoyed when they are told '‘ 10 days too two weeks, you will get your item back’' you guys are that busy ? YES, IT IS.
you are not the only person in an area of 70,xxx + people with a piece of equipment that needs work…
there are other shops in town… but they only service mowers/ weed whippers….the shop i work at services just about anything with a engine on it…but not atv’s, golf carts, or motorbikes…thats another ball of wax to deal with….plus there are other bike shops in town that do that stuff.
also 2 large snowblowers that the boss bought at the end of the snow season last winter, hoping to sell them and make $$$$ but they never sold…so those are taking up shop space in the back…
saw the two bosses looking at the rack of dead weed trimmers (99% have bad pistons/ cylinders, the other 1% parts are NLA ) and i overheard them say to each other that they will get me to fix them this winter for resale next summer…. :sick: i have told them numerous times that they are all dead or parts nla, but its better if they stay in one piece, so if a customer or myself needs a part, i can strip it off a similar trimmer/ chainsaw, instead of digging thru boxes of random parts…. :-/
they just dont get it :-(
fireflyse liked this
#10378
again the bossmentioned to me that '‘this winter you can fix those trimmers to sell’‘ and i had to remind him that the majority of them have bad engines, and the others you cannot get parts for them….but he thinks that i can ’‘frankenstein’' them and we can sell them for….$100 each…..
ummm
can tire is selling new gas trimmers for $129…..NEW….WITH WARRANTY…
sure, they are cheap, but they are NEW. not some rebuilt pos with mis-matched parts , that when it breaks again, you cant get parts for it…
earlier this week i did 5 trimmers in a row; 4 of them are junk, bad engines, and parts nla….the customers told us to salvage them, so up on the shelf with the other 30 + trimmers and parts….
there is no money to be made, by repairing and selling some of this stuff…the boss doesnt understand the math, of what it cost to fix vs. what you sell it for….then the cost of warranty on said used item…i hate patching up and selling junk…makes a person / business look bad….
#10381
Wow $300 for a carb on a lawn tractor….
Customer left it very low on fuel, water got into the carb, then it froze….hairline cracks inside carb, keeps leaking fuel, to the point where it loaded the crank case full of fuel….when I removed the spark plug it was like a geyser of fuel that came out…..
#10385
lawnmower came in, complaint of not blowing the grass into the bagger '‘good enuf’‘- ’‘ my neighbor tried getting it to rev higher, now it doesnt run’'
what a mess. its a simple bend of the governor spring mount to increase /decrease rpm….BUT NO, buddy decided to bend the entire bracket, as well as put custom bends in the governor rod, as well as make it shorter. then the springs were modified for the auto choke return and the main governor return spring…. :unamused:
oh and the gas was yellow and stale…the carb was dirty….
so, customer didnt want a '‘tune up special’' ( too expensive , says customer… just fix it)
so i did. it recieved a full tune-up, as well as the parts needed to correct his buddies '‘custom’' tune up work.
i cant make a engine run properly with a dirty carb, air filter plugged, and worn spark plug. and i changed the jet black oil as well.
so after all that plus the parts his buddy wrecked it was well over the tune up special. oh well.
plus made a note on the repair order for customer to wash out their bag….they do get clogged like an air filter, and then it doesnt let the grass in as easy as it should…
#10387
cranked out 8 mowers, a pressure washer, and a 35hp v-twin on thursday, as well as a walk in repair recoil and blades sharpened….was in a good groove, things went great….
friday i did some extra shop cleaning, then near the end of the day fought with a mower that wont run right….like its running out of fuel…had it apart twice to check everything over….just left it to the side for monday.
had another '‘warranty’' claim from can tire….‘backfiring / black smoke’ . went thru the entire checklist, from fuel, valves, carb, air filter, coil…turns out it was a faulty spark plug…install a good used ngk test plug and it runs great…
so , install a new ngk plug, bill the warranty company for that and an hour of diagnostics….
had a unit with tiny cracks in the carb- those parts arrived and it was an easy finish on that tractor. their mower deck was actually clean, and blades were in great shape. its usually the opposite :laugh:
its supposed to be really hot next week- like above *40 c hot….
#10393
quick job on a gen-set…'‘ just quit running, needs carb work’'
well, pulled the carb off, someone else had the bowl off, and LOST the main jet….
it was not a carb issue…but now it is….
and it was the lash adjuster, on the intake valve, that had backed off COMPLETLY, letting the pushrod fall out of place, therefore the intake valve was not opening….
i aske the owner who else worked on it, and he said his employee did…..so i told him what most likely happened, when these type of carbs are taken apart THE WRONG WAY the plastic guts (and brass jet) fall out of place…
the jet is fairly small, maybe the size of a larger match head- easy to lose.
the proper way to service this type of carb is upside-down…in the vise….with a clean work area, making sure that you dont lose that jet. not on the tailgate of a truck, outside.
new carb is $500+
owner of generator is not happy with his employee…a '‘i think i can fix it’' person just cost him ALOT of money…by not knowing what they are doing.
i showed the owner how easy it is to lose the main jet….
oh well, keeps me busy.
  • 1
  • 11
  • 12
  • 13
  • 14
  • 15
  • 16
Just resign your membership now spammer
Casper 2.0
I can set the timing anywhere but if I add boost a[…]
MK1 5 Speed Transmission
Thanks Dale , looking forwards to hearing from you[…]
Breezy
https://www.youtube.com/watch?v=j2LVIAKlDwI
