- Sat Dec 12, 2020 10:37 pm
#9704
BLUF: Is there any conceivable difference between a Metro front LCA and a Swift GT LCA for any Mk2/3 car?
Because I see the Moog catalog actually lists only one part number for Metros and Swifts 89-94 on the RH side, but has a separate part number for the LH side that ONLY fits 89-94 Swifts, NOT Metros and now I’m really confused. I hate buying stuff that doesn’t fit!
In the rockauto catalog, it also shows the Moog parts as having different “maximum extended lengths”, but the value they give for the part that fits Metros AND Swifts (LH side, moog RK620305) matches the correct measurement from bolt center to center of ball joint, and the value provided for the “Swift only” RH LCA (moog RK622717) matches the correct overall measurement of the arm along the long axis
I am pretty sure they should all be dimensionally identical! Moog lists what I believe should be an identical part for the Metro only on the LH side (RK620306).
What’s up! Anybody else notice this? I also notice that other vendors have the same part number for both sides, Metro or Swift same, just as you’d expect.
Back story: I decided to finally go and get some new lower control arms, partly to rule out ball joints as the cause of an actual problem, and partly because they are original and have nearly 200k on them .
I cannot feel any perceptible “click” when disconnected from the knuckle to indicate play, and the wheels stay put when pushed and pulled along the vertical axis with the wheel in the air…but they wiggle very easily. If it turns out there’s no change at all in the alignment issue (which I’m not going to go into in detail in this post! Yet!) then I’ll just hoard the OEM ones until whichever new ones I end up with wear out, but I’d like to get a matched set that fits correctly.
FWIW, if anybody needs them, here are the OEM Suzuki parts #s for the LCA’s–I see there is a difference between mk2/3, which I assume is because they changed to a beefier front sway bar on the mk3 cars–though I am not really sure why that would require a change.
LH
45200-60820-000
45200-60822-000
45202-60B01-000
45202-60E00-000 91-94
45202-60E01-000 91-94
RH
45200-60810-000
45200-60812-000
45201-60B01-000
45201-60E00-000 91-94
45201-60E01-000 91-94
LH
45200-60820-000
45200-60822-000
45202-60B01-000
RH
45200-60810-000
45200-60812-000
45201-60B01-000
They say there is no substitute for cubic inches, but there is really no substitute for lack of mass.
